Starting a thread to document my progress of my e30 build.
Started out with a stock 318i with the M40 engine that i picked up for $900. Has 230+ kms on it, however this is likely more as when i purchased it, the odometer wasnt working. Fixed that up by disassembling and replacing broken cog gears with suitable replacements from an RC car kit.
The body is mostly straight, however the paint is wrecked and will be getting a full respray as part of the project.
Attachment 47235
Next up i picked up an M52b28, complete with G250 gbox and M50 intake manifold. As i'm in Australia, we got the aluminium block, not the iron block the folks in the US got so there was the risk of the block softening and causing issues with head bolts stripping the threads. All tests so far indicate that i've got a good block :)
The plan is to run single turbo on stock internals. To support this so far i have purchased the below:
- CES copper spacer and cutring gasket
- Raceware head stud conversion (ARP dont make any for the M52 aluminium)
- PTE 6262 turbo .82 A/R
- Tial 44mm Wastegate
- Good n Tight manifold
- 80 deg thermostat + cast t/stat housing
- e28 M5 (green) engine mounts
- metal blade water pump
- Renault Clio brake booster - the standard e30 booster will hit the intake manifold so a smaller option has been sourced
- e46 steering rack
Haven't yet pulled the head, waiting on cam alignment tools to arrive. Hopefully everything is still in decent condition. Test fitted the manifold however.
Attachment 47236
I will be self-tuning the setup on the stock ECU. Plenty of development work is happening on the MS41 series ECUs over on the romraider forums. Going to be a steep learning curve compared to my current experience with the MSD81 on my 135i however.
Still have plenty of additional parts to acquire/sort out before getting to the point of swapping the engine in such as:
- Radiator and coolant tank
- Fuel pump
- Injectors
- Relocate battery to boot
- SMFW and clutch
As i've been driving it around in its current form for several months, i also decided it was time to freshen up the interior a bit.
I managed to source an Mtech2 steering wheel for a decent price and had it re-covered and thickened up slightly. These are becoming incredibly hard to find.
Attachment 47238
Following that i also picked up a complete set of electric seats (front and rear) from an e46 coupe. Fabricated custom mounts for the front seats to use the factory mounting holes - none of this dodgy drilling through the floor which is apparently pretty common.
Rear seats required cutting the mounts out for the stock seats and relocating to suit the new. Also had to trim some of the foam on the lower half and re-trim the leather in order to fit within the width of the e30 chassis.
All in all took me about a day to do and i'm really happy with the end product:
Attachment 47237
As it stands, funds for the project have run a bit dry. The AUD is so weak at the moment and conversion + shipping rates from the US are absolutely killing me. Hopefully in the next month or two i'll have the head pulled and prepped to install the spacer and HG.
